protoj · Tuesday at 18:48 1 day
folling from ianl's post
we should start thread with vid/sounds ov our zed throught tunnels weve all got diif exhausts and engine noises and tbh ranting through a tunnel souns amazing obviosly at the speed limet:wink:
ill start it tomorrow need to go to irvine and guess what theyrs a good tunnel
Edited by zhoodyx
