manual gearbox supplier??
help ,i have a noisy 2nd and 4th gear ,a bit loud and grindy!looks like its had it, can anybody recomend a good supplier its a ninety swb non turbo,by the way i have checked the oil and its ok!. many thanks.
I had a problem like this in second and fourth when I first got mine. Turned out the rubber boot round the shifter linkage wasn't in properly so it let more noise through when pulled back!
I was convinced my box was knackered too. Might be worth a quick look before you splash out ....
Is the box the same as a TT 2+2? If so try a good breakers. Or import a new one from japan (£££'s) Or repair/recondition your own. Talk to SE or similar.
If the box is specific to swb you're choices are more limited and a repair may be the best way.
gearboxes of the SWB and 2+2's are the same.
You could even fit a gearbox of a NA, but this is not a very good idea though, since the NA-box is made of weaker materials.
[This message has been edited by lymon (edited 22-04-2002).]
