July 26, 201114 yr right to remove the sidelight lense ? im trying the screw on the face of the lense but just turning... is there another way to get em off for a bulb swap? without removing bumper
July 26, 201114 yr Thats the height adjuster You need to remove the indicator units (2 screws) then with them removed you can access the 3x 10mm nuts with a spanner holding the Sidelight/foglight unit to the car.
July 26, 201114 yr Author :blushing: got alot to learn about these cars it seems... so the headlight adjuster is on the face of the sidelights... wierd 1, ok i did try what you sudgested but only removed 2x 10mm, will go get the other 1, cheers much
July 26, 201114 yr :blushing: got alot to learn about these cars it seems... so the headlight adjuster is on the face of the sidelights... wierd 1, ok i did try what you sudgested but only removed 2x 10mm, will go get the other 1, cheers much no the foglight height adjuster is on the face of the foglight/sidelight unit ;)
