Who has the widest wheels front and rear?
Ok im looking to find how wide i can go with wheels as i just read someones post that has 9.5 inch on the front. What do you have, what offset and any work done to fit them?
Marty
had 285 35 18s and 285 40 18s on the shorty. those wheels on it, no mods, just raised the coiovers up to accept width. think its on 275s now....
19x10.5" all round :)
Ah jaffa my man what offsets you running and any spacers? I'm looking to run the same on the front and 11 on the rear what size tyres you on as well?
+35 offset, 15mm spacer on front
265/30 front
305/30 rear
^^ Yep, I doubt anyone is running as wide as Jaffa on the front.
Bear in mind that Jaffa has had extensive arch mods(rolling) done.
I presume your running 2-3 degrees (or more) neg camber as well Jaffa ?
The fronts stick out approx 6cm more than stock, and about 2.5cm more than the usual flush fitment.
Edited by Yowser
2.5 deg camber at front
Front wings were rolled as far as they'd go, in fact they were wider than my new +20mm wings
Rears rolled, pulled and flared. R888 tires also seem wider than other brands which doesn't help
I thought Jason farrow had twelve inch fronts ???
10" fronts, 12" rears - according to his Rides
9 j allround et +35 25mm spacer front 15mm rear .
255/35/19 front and 285/30/19 rear. So not the biggest but big enough.
what width rims though as i wanna go big :)
Whats that book???
No idea where I got that pic from, its been in my Zed folder for years
