Burning Smell and Smoke
Hi,
Recently whenever i boost there seems be a nasty smell that comes into the cabin, anyone know what it might be? It smells like burning rubber or something. Also i boosted it from 0-130 (private road) my whole cabin started to fill up with smoke.
Anyone got any ideas what might be causing it???
No smoke from the exhausts or anything!
Cheers!
probally oil blowing out the rocker covers on boost where the valve covers become positive pressure. buy a fire extungiser just incase, run your engine up to temp the blip the throttle on the cam cover, looking to the ear of the block you will probally see small plumes of smoke coming up. you may even see oil droplets forming under the car. its not uncommon it is highly annoying though. and in extreme circumstances dangerous. def needs investigation though.
So is this going to be an expensive fix or would it be something i could do?
If your doing plenum removal, you may as well do a water by pass while your there, then you dont have to worry about putting so many awkward to get to pipes back together
good call Vody.... there should also be instructions for that on the site I posted a link to... and also in the FAQ on this forum...
thanks a lot guys, i am guessing there is no other way to fix this issue?
lol... yeah, get someone else to do it... :)
might be a good idea to get someone to confirm that that is where it's coming from....
car up on a hoist and a torch so do the trick...
that way you could confirm it isn't a turbo oil feed ...
Well i had a look and cant seem to see any smoke at all, however there still the smell of burning oil or something. Checked under the car no leaks i can see as such. Just wondering who to take it to now lol
