protoj · Tuesday at 18:48 4 days
does any one know were i can get detailed pictures on engine dissasembly ,
as my tt has serious back pressure when u remove dipstick it looks like a steam train chuffing and burning oil smell from exhuast and dipstick tube.http://www.300zx.co.uk/forums/images/smilies/modern/taz.gif
