Car keeps stalling :(
3 times today my car stalled while I was slowing down. If I rev the car to 2,000 or so for a min and then let off it almost stalls. And today while I was stopping for traffic and once while slowing down for a corner.
Any Ideas?
Stuart
Check the electrical connections on the TPS first, followed by the AAC/FICD valves.
Ooga Jugga Wat?
Check what where?
Throttle position sensor - leave car ticking over and jiggle the wires - it it stalls then you've found it.
AAC/FICD is around the back of the engine - probably need to remove it to clean the connections (which is a bit fiddly).
AAC valve is called the IAA in this pic.
Stu,
the little box on the side of the inlet chamber, the thing I have been telling you to clean up the connectors on for ages!
see ya
Ahh so the fact the rubber surrounding for its wire is split could cause this? biggrin.gif
Thanks Andy, I cleaned the Throttle sensor and its seemed to have worked. Before it stalled all 3 times I drove my car yesterday. Now its not done it at all and I have done a few trips.
Why can it be twisted? Do you know?
Stuart
Just read your question again re twisted .... If you mean rotated then that is how you adjust it. Take a look at www.z-car.net tech stuff for details.
