fog light ducts and sidelights?
might be a stupid question but how do you fit ducts like car.mad's ones? i want to buy some from him and was just looking my fog is my sidelight? is their a way to fit side lights in to the indicator pods?
thanks.
Really easy to fit, using a bit of sikaflex or similar silicone based adhesive, might need a little sanding on the sides here and there.
You can have sidelights in your indicator housing, if the hole isnt there, you can drill one to fit and re route you sidelight feed.
yes, you can move the sidelights to the indicator housings.
I drilled a hole in the bottom of my 99spec indicator housings, and cut out notches for a bulb holder.
or if you get a set of 93 onwards Import indicators then they have an extra bulb holder for kerb side lights, which you can fit the sidelights into instead.
Gives the car a wider stance at night too, should of been there as standard imo
cheer guys, i like that, agreed should have been std,
i think i get a set of ducts off car.mad in the next couple of weeks...
car.mad (member here, and he sells on ebay). Yep, fit standard and most aftermarket bumpers.
