Power steering pump and hicas delete
deleted all the hicas system aswell as aiv egr aircon etc but I'm still trying to work out is it possible to use an na powersteering pump un modified or is it best just to blank off the hicas pipes on the tt pump?
Any help
Cheers Craig
^^^Yerp , NA Pump, Bracket and Pot.
You can swap over your TT pulley to it if you want to keep the same belt. otherwise you'll need a 3rib belt instead of 4rib.
Cool I've got the na pot already I'll get me self a na pump thanks guys
I tried the modded tt one when i deleted my hicas but for some reason i was getting pressurising back into the pot and basically blowing the fluid back out !!
Ripped it out and fitted an NA pump and bracket , sorted ,
BTW you,ll find the tt pulleys have a four ribbed belt and the NA has a three ribbed belt so the tt belt won,t fit , you,ll either need a NA belt or i just remove one rib on the tt one with a knife , that does the trick.
Also the mounting bolts for th NA bracket are longer than the tt ones . HTH
