Radio controlled cars
Hi Mark, i have a hobao Hyper .28 , do you have x 2 front wheels with the same tyres on as the truggy that will fit ( dont mind if they are used ) . and also a couple of decent glow plugs.
ta
Neil
so you got the hyper st Truggy or .28 TQ ? as above post reflects both cars
if its the hyper .28 TQ buggy wheels and tyres are £20>30 Full Set
if its the hyper ST Truggy .28 i dont stock the original wheels as there kinda poor as the spokes snap really easy
you would need to buy some 1/2" off Set rims and tires to fit this can cost from £30>£60 full set
Glow plugs are
£5.50 for LRP Platinum R4 Medium
£6.50 for LRP Platinum R5 Med/Cold
Mark
Do you own a model shop then Mark?
I have a few questions for you if you know about rc cars
what is the best all round truck the Traxxas T-Maxx or the Traxxas T-Revo?
Also my kids have both got tamiya touring cars and i cant find anywhere to get new shells for them. Do you sell them or do you know where i can get them from
ok yes i sell Universal bodys ( 190mm ) for all tamiya Electric and Nitro
the Prices are around £22>28 depending on car body type
ok Traxxas is a very good brand but you pay 20% more just for the name compaired to
Hobao
Hong Nor
HPI
Ansmann
Caster
the list goes on
the best thing is what do you want to do with the RC and how much do u want to spend ?
Can you get hold of Z32 body shells...
only
nissan 350z & nismo
nissan skyline r32 & r34
Nissan skyline GT-R
nissan Silvia
Thats all
well i want to be able to mess about with the boys and there touring cars in the car park but would also like to go off and do my own thing with it in the woods and at the local gravel pits. the T-maxx 3.3 and the T-revo 3.3 are both in budget so i guess you could say my budget is between £400 and £500
ok here are the good and the bad points about some cars ..
Traxxas 3.3 trucks
engine is very finiky to tune
T-Max
likes to roll over all the time due to high ground clearence
Not that strong Front wishbones are very weak
Good Points Very fast and handles quite nice
Revo
has a weak gear box blows the reverse gears all the time
both have a stupid Ezy start system that Eats batt life and pack up over time ( depends how it gets abused and used )
Good points fast and has Trick suspention setup
HPI Savage
Rolls over due to being high
Strips spur gears if engine gets knocked ( this goes with other trucks to )
a little lazy in steering but thats a monster truck for you
Good Point .. Very very very very strong !!
there all with in your budget and have change left over ..
if you was to come away from monster trucks and have a think about Truggys or Buggys
you could go for
Hong Nor CRT x1 truggy
big wheels like monster trucks but lower to the ground and would out speed and out manoover any monster truck going
Plus its very very strong
downside is that the Jumps are not has high due to being lower to the ground
but hay if yout thinking of doing 10ft jumps then trucks are good but remember is how u land them
buggy is more for Cheap playing and Racing
Wow what a responce. You defo know your stuff. I was going to change the arms and everything on whatever i get to alloy parts anyway just so i know i wont break it if it lands hard.
Do you have a website for your shop ad are your shells on there?
some shells are on there the ones i sell most of ..
Dont change any of the parts to alloy
it doesnt make the car stronger .... just heaver and slower and more expensive to repair if u brake some thing thats alloy .. trust me i been there got the t-shirt .. and seen meny other ppl with there mangled up cars
trust me i seen it all
salotape,glue,tieraps,wood screws,bits of metel straping stuff togeather
seen the after math of cars running them over
jumping them to high , runing in to trees that just come out of noware
i race on a Pro Level so i kinda get to see it all lol
cool i will save my pennies on the alloy bits then and spend it on tyres fuel and beer lol.
Is it worth changing the air filter that comes with them or will it not make much difference?
most of the cars these days come with performance airfilters
.21>.28 ( 3.5cc 4.6cc ) engines
Hi torq servos
2.4g Radio systems
All fully ball raced
Metel Gears
Take a look at the latest Design thay have done to the savage x 4.6
you would be looking at
£400 for car
£15.50 for Batt ( for electric roto starter )
£25 for charger ( fast,mains,12v )
£14.99 for starter pack
£16 for 1/2 gal of fuel
Extras
2.99 air filter oil
2.99 after run oil
9.99 hump pack Batt (for the car)
hay mark i have a thunder tiger sledgehammer truck which im stuggling to het to run tiddy. have you got any tips on tunning the engine so it idles and doesn't cut out all the time?
thanks
isnt the sledgehammer the one with the .50/.70 block engine ?
if so thay are a Pig to start and use
turn up the idle alittle more
get it started and try and run 1/2 tank of fuel
Turn the top end needle 1/8th of a turn clock wise at atime
untill you have good engine top end performance and a nice trail of smoke
the engine must not bad off under its own throttle (die)
now once you have done that u can tune the Low end Needle
turn this in 1/8th atime clockwise untill u have a nice Zingy throttle response
once this has been done back both needles of by 1/8th and then u can ajust the idle again so the engine ticks over nice but not engaging the clutch
engine must not get to hot
normaly u can tuch the top finn of the head for 3>4sec before its to hot to tuch this would be about right 200>250f
found it! ok thanks i will give it a go before i kick the thing accross the car park! i may have to get it set up by someone who knows what there doing as they are very potchy things! im thinking of changing to a baja 5 at some point!
wow u got some cash if your thinking of a Baja 5b ... with an RRP £1000+ lol
take a look at this i know it doesnt look the same but as more on it and 4X4 26cc and £400>500 less
http://www.cmldistribution.co.uk/cml_product.php?range=RACING&productId=0000004747
http://www.cmldistribution.co.uk/cml_product.php?range=RACING&productId=0000005179
no i wouldn't be looking to buy new! i would get a secound hand one as ive been told there pretty bomb proof. that your shop?
