Clutch pedal wiring
Guys Im very lost and confused, im trying to fit the clutch pedal for my manual conversion, but im getting very stuck on the 2 plugs on the clutch pedal, I have no idea what the 2 plugs are and if they need wiring in as the write ups im using are not very clear. can anyone help with what i need to do please!!!
mant thanks Craig
You dont need them unless your keeping your cruise control which uses only one of the plugs(i think its the black coloured one?).I never used any of them and aint looked back since..Lee
they are there so if you have your CC on, touching/pressing the clutch or brake pedal will cancel it out, obviously the clutch pedal wasn't there before, so you need to wire the clutch pedal switch in parralell with the brake pedal switch, so that either pedal will cut off the CC... Or you could just leave it, and press your brake to cancel the CC... HTH...
I don't have cc so shouldn't need either would that be right?
That should read in SERIES .
Jeff TT
