hi I recently purchased a 1988 non turbo automatic with a bad transmission another person gave me his transmission out of his 1988 turbo automatic after he did a manual conversion , when I checked there was a couple of guys in another forum that it said it will work as long as I used the same fly wheel and torque converter, the mechanic was not able to install the transmission using the non turbo torque converter and the non turbo fly wheel, so we used the turbo torque converter that came with the transmission and I found a turbo fly wheel, the mechanic was able to complete the install, but now the O/D button on the shifter will not engage the light stays ON on the shifter and transmission does not goes into O\D , I have seen a couple of different answers on the internet one saying that I can bypass the TCM on my non turbo by connecting the O\D solenoid to the shifter and other posts saying that the problem is that I used Turbo torque converter on a non turbo car, I am seeing different answers every time I check so I appreciate if some one with experience will tell me what I need to do
Alvarezchuy1 ·
First off, I love my car again, iv fixed almost everything that made me hate it ;)
anyway, the pump failed at the bdc under epic load :(
It's a TT, manual, in an NA shell (ie no hicass or hicas pump etc) the TT engine was/is running an NA powersteering pump, it's dead.
Iv got a TT powersteering pump, will it work? There are 3 pipes coming off it? Does one of them need blanking off or recirculating etc?
