Where does the Audio 2 wire run? To and from the fuse box...
In decoding the audio wiring on the Series 6, I discovered (thanks Nigel) that the later cars (perhaps from '95 or 96 onward) used the Nissan Micra connectors for the audio. (Wiring diags based on Daves_Zed's original are here.)
But we also found that the wire which should be delivering 12v continuous from the battery to the stereo, isn't. So my job for next weekend is to try to get that fixed. Do any of you kind people know where this wire should run so I can trace it? I think it should be the wire that is connected to the AUDIO 2 fuse.
Is there anything else which is normally connected to this feed and have any of you had a problem with it?
Oh, and how do I get the panel under the dash beneath the steering wheel off? I noticed the two obvious screws but something else was still holding on.
Thanks, Gio
havent got a clue about the wire,
but the under are dash trim with the tweed on it, has the two screws that are hiding in the black plastic recess's and 2 bolts from right at the lower edge, and one screw behind the air vent that the door closes on.
Smart, ta, vodkashots. Raining now so probably not tonight :)
