Is it much of a job to fit the top heater hose?
As above, got a bit of a leak, I've done a search on the subject but didn't come up with a "how too" thread.
Your help would be much apprieciated :bow:
Ta Steve :)
Firstly disconnect the battery and remove.Lift the battery positive wire out of the retainers across the fire wall and raise the engine wiring up on to the plenum (gives a little room) youll need either a long screwdriver or socket extension(depending what clips are on the hose) and a pair of extra long nose pliers.Its very tight for room and youll probably swear once or twice but 30mins should see it done...Hope this helps...Lee
Thanks Lee :) I'll get someone with more patience and less clumsy than me then :taz:
Its not hard m8 just a little tight for room .You can do it :laugh:
