Washer jets not working
Ok, mot is at 11:30, the windscreen washers arnt working and one fog light isnt working.
The rear washer is working, are there 2 seperate motors for rear and front?
Where abouts is the motor for the windscreen washers? Is it possible to swap the hoses from the rear washer to the front if theres 2?
Christ, why is the motor inside the washer bottle? What a stupid place, why can it not be just at the side?
Double check the hose is still connected to the bonnet. Otherwise all your doing is spraying water over your engine :)
I had a similar problem,
turned out to be the relay behind the drivers side front wheel arch cover,
corroded that bad I had to re wire the thing.:taz: worth a check first, as I too took the washer bottle plus motors out, pig of a job.:hammer:
Hope this helps mate.
You sure the jets aren't blocked? The motor on mine was working fine but the nozzles on the bonnet were blocked. Got a pair from a breaker on here.
