Hi
I have installed the Z1 hicas bar and removed the hicas + tubes to the back. But I was wondering if the hicas light was supposed to light up when the job was done. Do I have to remove the bulb?
You can do but then you will have to check the ps fluid level yourself. There was a post a while back talking about a mod to the PS ecu, but I can't find it.
where the cars ecu is there is another ecu under it for the hicas with a single plug going into it, just pull that out and job done.
by doing this you also get to keep your fluid level indicator :wink:
That's why I couldn't remember the mod.... Far to complicated :lol:
I understand can be hard for you oldies to remember things :tt2:
wish i had known this before i took the bulb out instead!:oops:
dan.:blush:
