Faulty Dett sensor code 34? running rich???
would a faulty dett sensor cause the car to run rich, also once bypassed will the timing go back to normal as i run an EBC.
are you sure your not getting DET? and that the sensor is working fine. my cylinder 6 piston has a whole in it, most likely caused by det in that cylinder, creating a hot spot on the piston and eventually melting through it.
ย
Id make sure its not DET first before doing the by pass. what fuel are you running as some of the normal 95ron stuff can cause det to occur.
ย
You will also need to reset the ECU as you will most likely be running safety boost (unless yours is a N/A)
twin turbo with boost controller, im 100% its not getting dett as i get code 34 which from reading on here means no signal from dett sensor, not actual det.
ย
its the wire itself causing me greif as sometimes with a little wiggle and reset the code goes away. and the actual plug itself doesnt stay connected.
Code 34 is a fault code,if the car detects detonation is does not register a code 34 it retards the timing and drops to a knock map if the ecu has one (some chips dont) which increases fuelling for engine protection.
