Remove plenum
hi has anyone got a guide to removing the plenum/inlet maifold off my 300 want to clean up all those groggy connectors to the injectors cheers
do the water bypass whilst you are there!
whats the benifits of the water bypass?, i dont know much about it cheers
Gets rid of water pipes you don't need, which are potential leaks, and also makes it alot easier to remove the plenum in the future, as it doesn't have as many pipes attached to it...
You can remove all of the injector connectors to clean them without removing the plenum.
