Oil Pressure sender
before i ask yes i used the search ..
found loads of post regarding the Sender unit failing but not what i'm going to ask
as the OEM sender is like £75>100
can a Universal one be used like this ?
http://cgi.ebay.co.uk/UNIVERSAL-OIL-PRESSURE-SENDER-SENSOR-1-8-NPT-THREAD-/260785906889?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cb80d24c9
as i asume the out put volt should be the same
any one tryed it ?
  • Replies 37
  • Views 1.7k
yeah ok ..
i know the thread is different 1/8 BSP
where as the others are 1/8 NPT
but the converter adapters are only £3 to buy
and it must work the same on Neg Signal Volt to the dial
and getting a sender to do up to 100psi .. most do anyways
just wondered of any one has tried it ?
cheers .. so it is possible just need to get the right one ..
have done a quick search for one he used but only comes up as a aus'y part only
got the Spec of the sender he used
Pressure Sender: 0-80 PSI/5 Bar 1/4-18 NPT
Part No: 360-005 Notes: 10-180 Ohms Single Station (for one gauge), Standard Ground
just wondering if its possible to use a 100psi/145psi sender .. its only the max limit of it and still should read around the 180ohms around the 80psi
as there only a tenna from flebay
  • 1 month later...
no Medallion Man never got back on this i asume hes forgotten about it or been biz'y
Mark
Hey... sorry mark... yeah, I got one off him but haven't installed it yet..
it is slightly different to the Nissan one, he assures me it's the right spec..
The OEM part number is 25070-30P01
A bit cheaper over the pond, 100 USD no more I would of thought with the postage which equates to £62, at least you know it will work :wink:
Update:
... they will most likely be about £30 and are for the 300zx, I'll check to confirm the fitment of the plug next week (when I fit it).
if you're desperate you could always go with the one on ebay.
cheers.
Thanks for that,but i'll wait and see what Medallion man comes up with.
cheers Paul
Update:
cheers.
I'm in no hurry, will wait until you fit yours.
cheers Paul
£30 is better than £60 + import tax and the 2 week wait ...
would be nice to have as uk supply that works anyways
Mark
