Conzults reading on a auto
Well given up with official software after it kept moaning that the cable wasn't plugged in so switched to the trial software, (yes it's a conzults reader/cable it's got it stamped on the big Gray box thing down buy the connector) anyway the trial gave me a fault codes and monitoring and not much else.
Car is a Uk spec TT, suffering a smoking issue similar to what artztogo's is like, smokes from idle, and when you put your foot down a bit, but then clears when crusing, only to smoke again once idle, and the gear box only uses 2nd gear and reverse.
And flagged up codes
34 for the det sensor
And code
54 for communication to auto transmission gear box fault
Haven't cleared the codes and done it again yet as I'm taking a break lol
But thoughts on the gear box error code would be appreciated, it's going to get changed anyway, was just interested in what would flag up code 54.
Need to do the det sensor by pass clear the code and see of the timing goes back to normal
It was showing my timing at 25 on idle and lean
Really wanted to use conzults to see what the gear box was doing as it's only got 2nd gear
Edited by vodkashots
Blimey!-25 degrees and lean-lucky you still a Z!:ninja:
Doesn't idle right it's got a bit of a judder, I take it that would add to the smoking issue it's currently suffering
lol see you back in a few hours then stressed! lol
Friday the 13th, didn't want to push me luck :lol:
lol you never know you might be like that women on Deal no deal, my mrs just showed it me jammy git won 250k :-(
Yeah but not filmed on the same day, anyway looks like the cam covers are coming off to check the timing belt marks ooh the fun lol
lol mines off the road atm slowly doing my 60k service!, when the mrs lets me! lol
anyway here you go, man its not looking too good lol, tps showing 48 degrees instead of 45 :blink:, timing showing 25 and the engine is lean.
tried doing a autobox code check, but dont have a A/T light on the dash, or the bulbs blown :lol:
Have you tried using ScanTech this also allows A/T Diag's??
Nope didn't even know it existed till just now lol
have you tried a reading when the engine is up to temperature?
dan.:biggrin:
Dan doesn't matter, this was just a screen shot to show what readings I'm getting, at temp the tdc is still 25 and the tps Is still reading a figure around 0.48v
have you tried checking the timing with a timing gun? seem to remember something about conzult showing 25degress at idle! may be wrong though! have you not got the user guide? having a look through mines now.
dan.:biggrin:
Well it sure is lumpy as hell on idle, it vibrates the car. Don't have a timing gun either so might have to invest in one lol
think it was to do with a manual conversion showing 25! worth investing in a timing gun though sure someone near you must have one you can check it with!
dan.:biggrin:
dan.:biggrin:
Yeah few garages around here, got A feeling it's not helping the smoking issue or low compression its showing
