advice please - fitting rubber bushes
Evening all, I'm about to install some rubber bushes and when getting the bits together I found some sachets of copper grease in an old pack with poly bushes for another part of the car...question is - do I need to grease the rubber bushes, and if the answer is yes, then am I OK to use the grease which was intented for use on poly bushes?
you don't really want to use any oil based product on rubber, the two don't mix. Fairy liquid is a good lubricant for rubber and plastic..
