Fitting fuel filler to tank!
Hi all,
What a pain in the arse i fitted my fuel tank ages ago and just needed to fit the fuel pipe on but had lost the screws that i also found again tonight:thumbup1:
Anyway mine doesnt line up correct! Is the flexi pipe ment to flex because mines fixed?
Is there an easy way to fit the pipe or am i doing something totally wrong here haha.
You may need to lower the tank slightly to get all the screws lined up properly.
I have not long re-fitted my tank, If the thing isn't blind on then the filler neck will not line up. I left my tank slightly loose so when I had fitted all the screws I could then wriggle everything into the right position. Hope this helps.
