300zx on Ph with 400 hp, realistic?
from what he has put i cannot see why not. depends on what boost and injectors he has??
ah thats been on ebay with no success its ok claiming but what does he mean by Hybrid turbos and does he have a print out. could just mean rebuilt tubs and trying to big it up. Would still need injectors to up the boost otherwise run lean
will be utter *****x for sure,most maps run around 370hp tops with that spec,id be very surprised if it was 400hp.That figure is achievable with loads of advance but tuners dont tend to market those maps in case of engine damage.
Spec is to vague to say.
Its potentially 400+ , but it really does depend on what spec turbo's its running and how much boost - and how much boost will be largely limited by what injectors and intercoolers its running.
Referring to the turbos as Hybrids does'nt tell us anything (even the stock turbo's are hybrids), but Turbo dynamics provide rebuilds from stock to T28r 5bolt size - which gives you a potential power range from approx 350hp-500hp (flywheel), respectively.
