she'sn started acting up
the other day the temp gauge shot up to pretty much the top stayed theyre for about 10 seconds then went back to normal..this only happens when the engine had het up..checked the temp sender sensor and gave it a clean still happenting
now the bloody pod that holds the window wipers and temp controls just insnt working no digital temp display no windowwipers or spray.checked the fuses and theyre all ok..im puzzled and help or ideas would be appresiated
any error codes?
to state the obvious..... sounds like an electrical problem, have you checked to see if the fuse box and loom in the drivers side kick panel is wet or corroded?
Basically the same as medallion man said sounds like a fuse box fault the drivers side targa drain pipe runs down the a pillar above the fuse box, if it's leaking the water runs down the back of the fuse box, if it is that (pita to get out) I have a working fuse box on my breaker matey
had a check for that when i was pulling the fuses..everythings dry
the targas do leak but not from the drain holes.
its just that its happend when the suns been blazing..guess ill strip down the a pillar and make sure theyr aint leaks in the tubing or sumat
