Hi y'all, been checking out my tyres and both fronts have seriously worn onthe inside. Anyone know why this is and the best way to fix.
Also where do I get the cheapest new 18inch tyres lol
Membership No 0780
INSURANCE GOOFA
Prob like mine mate,too much Neg Camber,can be Toe-in as well,need an alignment ASAP!
my last zed did this, there was 7mm left on the outer edge, inside was down to the canvas! :shock:
the reason mine did it was the front tension rods (if thats the right word?) the stick things that bolt with 2 nuts to the lower arms. the bushes were knackered.
suspension problems most prob, bushes?,inner track rods,trye pressures,has to be one of those things you tried jacking car up and feel for play up and down and side to side see if anythings got play in it
Worn on inside is almost definitely camber. Get tracking checked. Many places confuse Z31 300ZXs with Z32 300ZXs so make sure they're using the right figures which you can find here http://www.300zx.co.uk/cgi-bin/manual.cgi
If it is camber, standard top links are non-adjustable so you have three choices. 1) rebuild suspension with non-saggy springs and other bits so camber comes back into spec 2) find a shim kit 3) get some adjustable top link camber arms. For shims and camber arms search here or ask ZCentre/MJP
