Short piece of trim at the top of the door
How do I remove the above? I need to get the door panel off to sort out an intermitant window fault but the said trim has to come of 1st, it un clips at the bottom where it meets the the main panel but i'm stuffed if I can get the top part out. (The seat belts are on the pillar not the door)
Thanks for looking Steve
The trim is also held in with a screw, under the round plastic cover located on the outside, only you need window down a bit to get to it. use a magnetic screw driver, or the screw will fall into the door and be lost forever.
Hi Steve - if you mean the trim that runs up the rear door pillar then drop he window down & on the outside you will see a round plastic cap that you unclip - behind here is a screw, remove this & the trim can be removed :)
