Help please
need to replace some badly corroded brake lines, does anybody have a set of brake pipe bending pliers that i could beg borrow or steel, ( i have a decent flaring kit allready)
thanks
Neil
Personly i'd use the pipe pliers if it involves any tight or sharp bends to avoid kinking. I have none to lend though, sorry.
thanks, but im looking for tube bending pliers... they are a bit like bull nose pliers with a notch cut out on the back of them
Hi sayers.if your using copper you will not need a pipe bender.The copper is soft enough to bend without them..ive replaced lots of brake pipes over the years and never had a problem.Lee
no, im going to be using cunifer , copper is not reccomended and banned in some countries
kunifer is a copper/nickel mix its only a little harder than just copper alone but still bendable w/out tube benders.also apply a little heat with a hot air gun makes it easier to use..lee
