Actuator pressure.
Let's say one of the pipes that went to the actuators fell off (just one) what would the boost read? Would it run at all?
The actuator would remain closed so the boost on that turbo would be unregulated, however you then have a fair boost leak down the disconnected pipe, either way not a good idea as overboosting is a real possibility
Jeff TT
The boost gauge is connected to the balance bar, it's Reading no more than 12psi no matter what I set the greddy profec b spec 2 too
by unregulated like it would run upwards of 2 bet etc?
So your having problem making boost over 12psi? the most common cause of this is leaking recircs or slow closing dump valves, whatever the turbos spool up to unregulated or not they cannot overcome recirc leaks.
Jeff TT
Before the new engine it ran with blocked off recercs (I know it's stupid) and now there are no recerc vac pipes there just missing now and blanked off on the plenum side, should the recercs vac pipes be blanked off then (I know giving advice to an idiot that's blanked off his recercs is asking alot)
