I've got an ABS Fault and would like to find out specifically where the problem is :confused1: .....
If anyone can help in the Swindon / wiltshire area I'd be very pleased
Pete
Ah, problem is - I cannot PM Lol. So this is my only route of communication atm :P
post up in the thread asking for said person to contact etc :)
Or sub and get to pm, get to full forum, and get the membership pack lol
Pete
No need for a ConZult, the ABS unit has a really good in built diagnostic, the abs unit sits behind the drivers side, rear quarter panel cover, it has a fault diagnostic light on which can be seen through the seat belts apature by the seat squab.
Firstly drive the car for at least 50 metres and at at least 15 mph, stop and without switching the engine off check the abs light flash, count how many times it blinks, do not worry if you miss it as it will keep repeating the code, when you have the code check against the abs fault flash code table to find the cause of the problem, most common issue is wheel sensors and again mostly front one`s, this is especially common after work done on the front hub has including any hammer hits like when removing ball joints etc.
Jeff TT
