replacing turbos on car
can do it with the engine in, but getting the engine out is easy and you can do other jobs at the same time..
just guaging as many opinions as i can is all mate before i decide to pull the egine out to then be told there was an easier way
the garage i use does them easy with the engine in, and less chance of disturbing things you don,t need to,,, i use D2 in strood in kent,,, top zed specialist, he's worked on them since they were first out,.
i have my own pitt to work in and a pretty well equipt workshop have swopped the engine once before already
It,s a damn site easier with the engine out bud , the only down side is all the extra bits you end up replacing cos of things breaking whilst taking it apart , finding all those perished pipes and connectors and stuff but on the upside once all those little bits are done it does help give you trouble free motoring .
I did this myself and never had any of those niggly little problems again , no pipes springing leaks and dodgy connections causing running issues .HTH
