Water Leak
After finishing the rear suspension and plenum water bypass I finally got the car to start after fndng the loose CAS plug. I did the bypass as the thread below, once the car started to get to temperature something happened and all the water was dumped over the drivers side turbo and downpipe? I checked the bypass hoses and heater ones and they are all fine, any ideas? Is there another rubber hose for the turbo, assuming I've done one then there must be another like the two on the passenger side?
http://www.300zx.co.uk/forums/showthread.php?t=132280
Found the leak, not shown on the bypass thread it seems on some cars there is a 4th
8mm metal pipe coming off the drivers side metal heater pipe, it runs towards the wing behind the plenum and needs to be blocked off.
