door speaker size?
guys whats the exact door speaker size for a 300zx im just going to halfords to get some cheers
is it 16 or 16.5 0r 17cm? and does the depth matter do they have to be thin ones or can you have fattys with gurt magnets on?
6.5 inch (165mm), depth isnt a problem.
Edited by groover
thank u very muchage, got any spare ones graham? or any of the bits spare that i have listed on the wanted?
You might have to shave a bit of metal off the speaker holder in the door, or the other option is to do away with the holder bracket altogether and make your own baffle.
if you want an exact fit, screw holes and everything, you need a 6". there are only 2 current makes that fit exactly, kicker is one of them.
ย
6.5" fits in the hole fine but you will probably need to drill a couple of mounting holes if someone hasnt already
[sIGPIC][/sIGPIC]
