Ok so ive looked all over for this detail and cant find it so just to confirm once and for all for everyone what is the AR on the side of manual turbos?
I take it Auto ones are AR 48 but so far i havent found anyone with manual tubs to confirm what the AR is on them
Marty
if you don't get an answer before i go to my car at weekend i'll check on mine as i've got a few dead ones and some spares :D
cheers i never looked at the manual ones to remember but im sure i have some manual ones in pieces
48 seems too low to me, the difference between the manual and auto AR was only ever around 10 from memory.
Smithy
Smithy
i have a set of turbos here now they have A/R 48 on them and that is the same as everyone that has offered me tubs so far. Maybe the yanks are working on different measurements as usual. I havent seen a manual tub in a while so i cant remember the number on the side
Copy and Paste from one of my older posts :
Auto Turbos - A/R = 0.54
Manual Turbos - A/R = 0.63
Auto Camshafts - 240 degree intake cams & 248 degree exhaust cams
Manual Camshafts - 248 degree intake cams & 248 degree exhaust cams
Edited by Yowser
Your looking at the Compressor housng, which is 0.48 AR for both.
The difference between auto vs manual A/R is the Turbine(exhaust) housings, and I dont recall it being printed on the housing.
The difference between auto vs manual A/R is the Turbine housings, and I dont recall it being printed on the housing.
Oh gotcha so how can you tell if they are manual or auto?
Finally an answer for everyone to find out what turbos you have here are the part numbers courtesy of Mike at MJP :)
For JDM cars:
MT RH 14411-40P01 / -40P03 / -40P04
MT LH 14411-40P11 / -40P13
AT RH 14411-40P06 / -40P08 / -40P09
AT LH 14411-40P16 / -40P18
There are various supersessions, dependent on age of car.
