Ok quick one about the above as looking on the search no one has actually posted pics about doing this on a NA engine. From looking at my spare engine pic it looks like simply connecting the 2 red dots together as there is no turbos to cool and the lines simply to go to the plenum and back can someone just confirm this if you have a NA engine out as i sold mine last night and was meaning to check and confirm this. All the other piping then can be deleted making a very tidy engine :)
I blanked mine off totally, but you need link both sets of trees. Creating the loop
Ie you have 4x small pipe outlets 2 at the top and bottom of each pipe to the matrix, link the top to the top and bottom to the bottom , so all you are left with is the 2 main pipe outlets to the heater matrix.
Do it neatly...:cool2:
Cut off the little side pipes and weld/braze the holes.
Saves having more bits of garish coloued silicone pipe under the bonnet:wacko:
i like your thinking
