Prop shaft bracket/bearing
after getting the box out last weekend to fix my clutch problem i noticed that the bracket supporting the propshaft about halfway down was a bit loose, the rubber seal around the shaft was split.
Is this possible to replace or does it require a new propshaft?
I do remeber seeing this and the idea was mentioned between me and my mate. however, depends on how much a new bearing is, and whats needed to fit it.
Its about £180 for Proshaft bearing.
As for the one piece, Nothing extra is needed for fitment. Labour for fitting is about the same (In fact, slightly less) than fitting new bearing.
Edited by Yowser
not a fan of paying for labour, probably tackle the job with a mate. i'm thinking it would be easier to fit a new prop than to change the bearing,
what does it involve to change the bearing? just a hydrolic press?
No Stevie, you will not need a press, a soft mallet will do the job.
Paul
does it involve taking the old prop appart? i.e, the pivot point in the middle?
yep.
Drop exhausts
Unbolt prop from Rear diff.
Unbolt Bearing carrier
remove Propshaft
Seperate/Unbolt the two halves
Replace bearing
Refit it all
pretty straightforward and that low speed cold vibration gone.
Just need to add, BEFORE splitting the propshaft use tipex or similar to mark the relative flange positions or you will loose the dynamic balance.
Jeff TT
chears guys, still unsure about which to do though, change the bearing or get a single piece shaft.
Personally I would get the one peice propshaft.
There's not much of a price difference but a one peice propshaft is a lot lighter, and reducing drivetrain weight improves responsiveness, acceleration and reduces power losses.
You can go further and combine with a Lightweight crank pulley and Flywheel like I have, and have a car that revs and responds to throttle inputs a lot quicker. A very noticable difference that makes the stock setup feel lazy.
Edited by Yowser
Jeff TT
Wise words.
Also, take note of the bearing carrier spacers location. Seen them fitted in the wrong place a few times, which will cause similar vibration issues.
^^^ Thats if fitting new bearing. A one peice does away with all of that.
