Rear Hubs
Any guides for the removal, assume calipers, drive shaft nut and the vaious suspensin components disconnected?
exactly as you've said plus the handbrake cable. bottom wishbone ball joint is a taper but its a very coarse taper so when the nut is removed a swift tap on the wishbone and it should separate easily.
Biggest problem is drifting the driveshaft out of the bearing, you may need a proper hub puller, and when I say proper I dont mean a halfords special. I mean a big heavy duty hub puller as the shaft can really seize tight in the bearing. :surrender:
