In depth - Shells
Hey guys
One for the more clued up of us all.
The crank shells, someone mentioned to me they might be colour coded and in which case i should leave it the f*** alone!!
is this true?? i can only see numbers on the backs of my shells?
Latz
Latz,
The crank bearings are numbered to suit the crankshaft journals. This is just a grading process and things like pistons also have similar numbering to suit each block. If you want to change them then these numbers are needed for reference.
You can check the bearings for wear but as your engine is stripped down, you could opt for a nominal regrind of the crank with new matched bearings. Would probably cost you around £200.
I had a tri-metal race bearings fitted in my Z although Nissan OEM bearings are more than adequate.
Steve
cool! thanks steve
how much where the tri - metal race bearings? just curious. have ordered the nissan ones but not sure if i should go for stronger ones?
cheers
Latz
Latz,
How did you order the shells?? You need to cross refrence codes stamped on your crankshaft and codes stamped on the bottom of your block. I still have this somewhere.
RCD
oh shit. thanks for pointing that out. i'd better get back to the suppliers then!!!
what codes am i looking for exactly please m8?
Latz
  • 3 weeks later...
thanks dunk!!
i thought i'd pissed you off m8!!!! Yes please please please. i had a look at the one in the service manual. is it the same???
cheers
Latz
I am about to scan it now and post it. If file is too large, I will E-Mail to address on your profile. biggrin.gif biggrin.gif
Robert.
Here you are Latz mate! Print this out, study and understand it, then work out what grades of bearings you need. Please excuse the grubby fingerprints, but you do get dirty messin' with engines!! biggrin.gif
Also you can see my working out for the bearings I needed. 6 big ends and 4 mains.
http://www.300zx.co.uk/rides/dunk300zxtt/scan_small.jpg
Any way, I will now send a hi-res scan to your E-Mail address. Use this one to print etc.
Robert.
