starter motor
Hello,
starting to find a few little problems now, which I new I would, when I start the car you get that noise, as if you were trying to start the car when the engine is one if you know what I mean, doesnt happen all the time, Iknw the guy I bought it off changed the starter as the old one was lazy, any ideas?
Cheers Mark
Worn teeth on the ring gear?? It always comes to a rest in the same place virtually hence the wear in one bit of it.
Maybe?
was hoping you werent going to say that, maybe a new flywheel when I get the clutch then lol.
Cheers Mark
Other possibility is that the Starter has worked loose, very common for the bolts to undo from vibrations and the starters movement usually ends up snapping the top of its mount.
cheers bud, will have a check tommorrow.
Mark:-)
i have literally just changed my starter today. it was the bearings in the starter that were worn. i was worried it was the ring gear too but it was just the starter. ps the part number for a blue print one is adn11255.
Thanks alot mate, were you getting the same noise as me?
Cheers Mark
