Cross reference parts. help on input
I'm creating a cross reference chart, that i will put into FAQ.
Basically i need any info you can provide on what parts from other cars can be used on a 300zx.
The format im trying to sort it in to is:
Part Required - 300zx
Part from - Donor car
Location on donor car
Member- who has tried and it works.
Any modding needed..
Comments - Direct swap / part number if possible
Example.
300zx rear number plate bulb cover.
Any similar year Micra upto 2000.
Rear number plate bulb cover same item
No modding, but Nissan use different part number.
Im working through an old thread, at the mo, cross referencing parts we can use from other cars. Once i have a few parts, i will create a thread in FAQ, and make it as easy as possible to locate and replace some of the items that are becoming rarer.
You help is greatly appreciated folks.
This will benefit all of us.
Stu
Thats a great idea Stu, will have a search as well to see if i can add to it.
300zx headlamps.
Any Lamborghini Diablo SV you may find in the scrapyards.
No modding, direct fit :thumbup1:
temp sensor from micra will fit and work on a zed
Heater matrix from a 1997 primera P10 fits spot on and £200 cheaper
