tie rod/ track rod end ?
is this a lengthly process to have them removed or changed? need mine doing as the lower arm is bent, but cannot get garage time at all this week, everywhere is booked. :ohmy:
also is it quiet straight forward and how long should it take, only doing one side so tie/track rod. then tie/track rod end?
Is it just the trackrod end you need changing or the tie rod as well .The rod end is easy break the lock nut on on the tie rod arm .Then undo nut on the track rod end ball joint this may have a plit pin in some have nyloc nuts. Then get a ball joint breaker scissor type is best if not use a fork type, fork type will damange the balljoint boot but this wont matter if your changing the joint.Also you only need to crack the joint on the tie rod arm its a good idea to mark the position of the nut with tippex or paint to make sure you get it back in the right place .The rod end should just unscrew from the tie rod .You may need your tracking adjusted after.
taff by any chance did you once own a black SWB TT? in the colchester area :-)
No ive got a yellow pearl manual tt slicktop had it 6 years had 200sx s before.
shame, you dont know of anyone called 'nick' who used to own one do you, its a swb tt in black with black wheels. big front mount intercooler and 2 large rear 4.5inch exhausts? or you know of the car??
also mate if you up for it, theres a jap meet tomoro night at the halfway house in essex 7 30pm till late, over 100 people attending so far.
me and gonzo are going in the 300zx's.....
