What is a spigot
Sounds daft but I'm not 100% on what this is (as relates to gearbox). I'm stuck between a brass bushing that goes on the crankshaft? or a clutch release bearing? I'm not a mechanic so, unless I've had to deal with the problem on my zed, I don't know :blushing:
when i mentioned it i am reffering to the oilight (bronze) bush i call it a spigot bush that goes into the crank to take the gearbox shaft
Edited by hellraiser
when i mentioned it i am reffering to the oilight (bronze) bush that goes into the crank to take the gearbox shaft
That makes sense - cheers.
