Driver side window
My window won't operate at all and I'm led to believe that this is a common 'Z' problem.
The motor and switch have been checked and appear ok so is the problem with the regulator? If so, can it be rectified or is a new one required.
Cheers!
normaly they are prone to dry solder joints, remove the black box in the drivers door and resolder the connections in it, hopefully should sort it for you, also try wiggling the window switch while trying the window. hope this helps
