totaly miffed..
can anyone help me please.Just fitted delimiter and kph converter at the weekend meant to be fit it and forget it but dosent seem to work in mph plus engine keeps trying to cut out when slowing down at junctions..
Sound like you have more than one issue, the speedo issue what ever it is will not cause engine issues at low speeds, thats more likely a set up on the idle control valve / base idle.
If the speedo is working but still in kph then sound like the wiring connections are not quite right, did it come with a connection diagram?
Jeff TT
Yes it came with a diagram on how to fit it.It was off ebay should have shopped about first before bying it from there....
Not necessarily, could be a simple mistake in cable identification?
Did you fit it into the wring loom or the back of the speedo?
Jeff
