NA/TT Rad fitment difference
Hi folks quick one ive read that there is a difference in the mounting on the NA and TT radiators at the bottom. Im going to fit my Koyo rad to the NA and wanted to make sure it would fit before attempting and dropping the coolant
Marty
two bottom pegs is right. Also top hose is a different shape, top rad brackets and fan shroud is bigger.
Think Zedwizz was selling adapter plates for the bottom 2 pegs mate, ask him.
Top hose is simply use a TT one and rad brackets are a struggle even using TT ones, could use the top stainless covers that Luke and Danny sell and simply drill 2 holes in the slam to fit, pretty easy.
Smithy
thanks guys pipe not a problem i have a Z1 kit, binning the shroud along with the viscous fan as going electric and binning the brackets as have a plate from Luke already :)
so all this talk of having to weld in a TT crossmember is unneccessary?
Completely .
Two choices Re locate the existing bottom pin holes Or make/ buy an adaptor to go from the existing hole to the new location.
Gaz/Hellraiser put up a pic a while back.
somewhere
come on Gaz, get 'em found! :thumbup1:
will be at work as i made it at work, so not gonna check till tomorrow bud:sleeping:
can you still make them, if so what cost would it be? :tongue_smilie:
can still make them . should have the program in the mill at work with all the relevent info. costing not sure of .. people dont seem to want to pay for the time and materials anymore...... i put the question to you, what would YOU pay for a bespoke rad bracket?
I've got no idea where to pitch a figure :wacko: £20?!
