R33 GTR Calipers, what discs to use?
I have some Black Brembo Calipers from a R33 which i bought from a member a while back. Now im a little lost as to what discs to fit to the front.
I have seen around some discs, but they are 280mm, 298mm and 310mm.
I am not using relocation brackets as these should fit straight onto the standard caliper brackets on the hub.
So the question is what disc is the correct ones (for the front)?
They are 324mm. Standard size, straight fit without brackets. Anythng larger will need brackets and anything smaller wont fit. Any you've seen that are 280/298/310 are not for the R33 GTR.
Just search for R33 GTR discs, there are loads out there. You must buy R33 GTR fitment, its not just the Diameter and thickness thats important, but the hub offset, pcd..etc.
Edited by Yowser
