No side lights, just full beam??
Hi, I`ve just noticed today that I`ve only got full beam lights? If i turn the switch to side lights I get nothing and then switch again to the main lights its just the full beam and the blue dash bulb lights up, I pulled the stalk back and fourth and nothing happens, any suggestions?
Daz
fuse has blown. 3rd from the left top row red 10 amp fuse :wink:
:bow::bow:
Nice one dude, just done it and all is well :thumbup:
I`ve still got this problem??? No side lights just full beam, fuse is still intact , indicators work and so do brake lights???
Any suggestions please
Which fuses did you check ? The culprit is typically the one on top row in the drivers footwell.
Full beam is hte safety state for when there is a problem, to eenable you to see where you going still if the circuit breaks.
Look at the relays in the large fuse box pasenger side front of engine, think it's a blue relay, should be marked on the lid anyways.
You might be able to swap around 1 or 2 of them to confirm it is a relay.
smithy
I`ve checked all the fuses in the drivers footwell, but not checked under the bonnet yet :sad:
smithy
Ok, many thanks, I will go and have a gander in a min
Daz, I had this issue with Zedward - replaced the fuses, bulbs, nothing made any difference. Turns out I had an earth issue which an auto electrician has to sort out for me in the end :pinch:
Ok Thanks Jan!! I`ve been messing around with the fuse box and wires of latley so your probably right, it was working fine before i messed with them, thanks for the heads up :cool3:
You will continue to have problems until you chrome up all the fuses :tt2:
No theres an idea!!!!! :tt2:
Bah I had this, it was a 10a fuse in the drivers footwell.. and then it went again an hour later... and again 2 days later lol! Pissed me off being sat upside down in the car at night refitting fuses :p
What was the problem in the end bud? did you get it sorted?
CheerZ
Have you checked the relays/fuses in the main box in engine bay yet? dam site easier than the footwell one lol
smithy
CheerZ
I know the answer to this Daz - he put a nail in there :tt2: Didn't blow after :whistling:
