The 300ZX also holds the E/BMS land speed record of 260.87 mph
The 300ZX also holds the E/BMS land speed record of 419.84 km/h (260.87 mph) from the 1991 Bonneville Speed Trial.[8]
Hey, just found this? This is a cut from wikipidia, does anyone else have any more info on it as I`ve never heard this before?
eg
SPECIFICATIONS '91 BONNEVILLE
VEHICLE NISSAN FAIRLADY Z
ENGINE TYPE VG30DETT
BORE / STROKE 89.0mm / 83.0mm
TOTAL ENGINE DISP. 3096cc
COMPRESSION RATIO 8.3 : 1
MAX BOOST 2.0kg/cm2
MAX POWER 1000ps
MAX TORQUE 90kgm
SETUP PARTS
CAMSHAFT JUN High Lift Camshaft IN/EX 272 9.5mm
VALVE Noraml (processing)
VALVE SPRING JUN Original
VALVE RETAINER JUN Original
PISTON JUN Original
CONNECTING ROD JUN I section form Connecting Rod
CRANKSHAFT NORAML
TURBINE BLITZ KKK K27 X2
WESTE GATE BLITZ TYPE RC X2
BOOST CONTROLLER BLITZ
INTERCOOLER ARC TYPE III
INT MANIFOLD JUN GT-Surge tank(Prototype)
EXH MANIFOLD JUN Exhaust manifold Prototype
MUFFLER JUN Prototype muffler
RADIATOR JUN Prototype
OIL COOLER TRUST
FUEL CONTROLLER JUN CPU
FUEL INJECTOR JUN Injector main 890ccX6 additional 550cc X4
FUEL PUMP/TANK BOSCH X2
CLUTCH OS GIKEN triple TS3B
TRANSMISSION Original 5speed cross transmission
DIFF RATIO 2.4
LSD
TIRE GOOD YEAR / MICKY
WHEEL SPEED STAR
SUSPENSION JUN Original
