Loom connectors
Hi all,
Ive got a brand new loom to connect to the engine but my injector plugs on my loom are the older type pre 93.
As ive got the new type injectors installed im going to have to change the connector plugs.
Ive been told i can change the connectors over without having to cut and solder the newer type on. Is this true? Has anyone done this before?
Cheers Dan
you should be able to change them over, if you use a precision flat screw driver or small rod, you should be able to push it in the connector and then ease the wire out of the connector, they are just push fitted into the connector and held by a small tab, the screw driver will push in the small tab causing it to release, just pull the connection out then, just make sure it goes into the correct position on the replacement connector. will stick up a pic in couple of mins.
