5 things to change..
Hi again,
Wanted to find out - i got imported Zx from Japan (1994). It's stock, nothing's modified, etc.
What would you change in order to get it more responsive etc? I only mean engine-performance wise.
Maybe you could list few things to change immediately.. :)
Decat
Air filter
intercooler(s)
More boost.
Chip/remap
Should be over 370bhp then..
It is a turbo isn't it?
As mentioned;
Fit a catback exhaust, replace air filter with cone induction, install boost jets (cheap, may cause boost spikes) or electronic boost controller (much better option), and an ECU remap (chip). Do all this and you will see a massive increase over stock.
The above is assuming it's a turbo you've got. An NA will benefit from most of the above, excluding the boost jets/ebc, however the gains wont be as much.
Edited by Steams
get some go faster stripes!
sh£t youd need a hell of a lot o stripes
like been said m8y sort out the air flow first and youll realise a better throttle responce over the rev range
Decat
Air filter
intercooler(s)
More boost.
Chip/remap
Yep - its turbo (lucky me). Cheers for answer :)
I tried, put like 9 of them on the roof (and few on sides too) - nothing happened... :online2long:
As mentioned;
Cheers, very helpfull - will get it done asap .. Any preferences over Boost controller? Makes?
1st of all you will need a health check. and also make sure your not in safty mode etc :)
true mate, very important before you do any performance upgrades.
Thank's - actually i will do full engine refurb from next week (just to make sure everything is in order).
What is safty mode?? :blush:
safety mode is exactly that its the cars way of protecting its self if you like, if it reads certain faults it will enter safety mode or (limp home mode) to save further damage
your Jdm will also be restricted unless its been removed
Just to add to the above, in safety mode the car won't boost above 7psi, where as a healthy stock zed will boost to 9psi.
Great, cheers for explaining this..
Doh! .. what is JDM?
Jdm= Japanese Domestic Market, it's just the term most use over saying import :)
