friggin door cards!!
I'm sure I'm not the only one that struggles getting them back on. :pinch:
Is there a technique to doing it? I can never seem to get it hooked over the top at the front and the back at the same time until I start getting pissed off with it and violent lol... but I may benefit from knowing the trick of the trade. Its one of my most hated Z jobs even after owning 6 of them! Need to refit my passenger side door card tomorrow morning before jetting off to zedworld. :clap:
You might have the angle wrong, you need to get it as flat to the door as poss so that you slide it down on the top edge first.
it wouldn't be the first time I've used a size 10 boot :lol:
Window down, hold panel at an angle with the front down, and slip under the mirror quadrant push forward and whilst holding it down slip the back down and it should pop into place.
Jeff TT
I always found that you have to put the forward top on first, then just start pushing down and towards the glass, working your way towards the rear of the door. Glass down for best results, which may be difficult if you cant raise it afterwards!!
Jeff TT
ahh thanks jeff, but hope thats not the only way :no:
had to put a 12v feed to the motor as the window was stuck down earlier as its got window problems. so the window is now stuck up lol :wacko:
reverse the polarity on the motor mate and it will go down.
Have a think about that statement!! ;)
I can use the switch to put it down :tt2:
I mean when using the battery method, to switch the wires around and the motor will run the other way. I think... lol
what cha moaning about then willis!! lol
What I meant was...If Baz puts the door card back on with the window down, hows he going to get to the motor to power it back up?? :D
doh! :lol: Hadn't thought about that :lol::lol:
:slap: you helped earlier but now you're just a HINDERANCE :lol:
You can do it with the window up, it's not as easy and you can't screw the 'B' pillar trim back on at the top (as the screw hole is behind the glass), but it can be done
